Hello All,
I wonder if you can help?
I have a DIVX file which I am having problems with. The only thing the file will play in is the DIVX player itself. I have all the codecs installed but nothing else will touch.
I am trying to convert the file to DVD but nothing will touch it there either. I have used DIVFIX and it looks like it's doing it's job, however, the 600mb + file that it creates only plays for 11 minutes 22 seconds. On the DIVX player, the file plays for one hour and 15 minutes.
The error that I am getting is that there is no index, DIVFIX does say that it's rebuilding it but as mentioned above, when it's finished the file only plays for a short time.
Is there anything else out there that may be able to help me (virtualdub just spits it out) I am hoping that there is a piece of software out there that will capture it whilst it is playing on DIVX??
Hopefully You Can Help
Many Thanks In Advance
muso
Thanks for the reply.Originally Posted by jyn999
Here are the details:
File Size: 698mb
Video Codec: DivX 3 Low-Motion
Runtime: 01:18:48 (141,682 fr)
x:y: 512x384 (1.33:1) [=4:3]
Audio Codec: 0x0055(MP3) ID'd as MPEG-1 Layer 3
Bitrate: 135 kb/s (67/ch, stereo) VBR LAME3.93
Stream Type and A/V Interlace
Type: OpenDML AVI IMRR: 1.00
I/L 1 vid frame (33 ms), p=480 Split: no
Comments/Metadata:
CODE NAME CONTENTS
ISFT Software Virtualdubmod 1.5.1.1a
JUNK (ASCll in junk chunk Virtualdubmod build 1639
JUNK (ASCll in junk chunk release
Hoep this is what you asked for.
Many Thanks
muso
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
TS file problem
By _migz_ in forum DVB / IPTVReplies: 8Last Post: 20th Oct 2010, 16:04 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Problem File, cannot convert it.
By sigung in forum MacReplies: 9Last Post: 14th Feb 2008, 13:15
