Hi all. I recently got myself a DVICO Fusion MPEG2 card and it captures nicely with great AV sync when playing the mpeg on Power DVD player. However when I convert the mpeg to VOB files the audio sync is out for some reason. I've tried with Ulead Video Studio 7 which has an inbuilt DVD authoring program and tried it with Power Producer as well, same results. I'm worried that these programs are rejecting any mpeg I capture from the Fusion card as also Win Media Player 9 and Real Player give error messages when I play mpegs captured from the card.
I'm looking for a decent freeware MPEG-DVD converter that will do the job good or I'm after a program that will split the audio and video as I might be able to get them syncing good when re-combined in DVD format. If anyone can help me I'd most appreciate it.
Cheers
Troy
AUSSIE!!! AUSSIE!!! AUSSIE!!! OI!!! OI!!! OI!!!
I had this same problem with teh caps from my Hauppauge card. Teh program VideoReDo has a "Quikstream Fix" option that rewrites the GOP sequence of the MPEG (when an MPEG has a bad or damaged GOP sequence, this causes the sync error in authoring). I'd highly recommend that program to you. It also does excellent editing of MPEG caps, like removing commercials.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
DVD Lab Pro - Using VOBs, Audio Problems
By teacozie in forum Authoring (DVD)Replies: 5Last Post: 24th Sep 2008, 01:12 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07 -
mencoder converting realmedia files w/audio sync problems
By kruuth in forum Video ConversionReplies: 9Last Post: 26th Sep 2007, 15:34
