without using vfapi
rename the *.vdr file to *.avs
(assuming you installed virtualdubmod frame serving)
works like a charm![]()
Results 1 to 9 of 9
oh yes --perhaps so... i have it installed , so never tried not installed ..
After running into the same set of problems as others, I have installed AVISynth and I can now finally frameserve to Procoder 2. Thanks to all of you who participated in these threads. It is wonderful to be able to launch a problem on these forums and almost always get the answers. Whatever did we do before the days of Internet
Now if only you guys could solve my major problem...Mother-in-LawShe parks her broom in my driveway way too oftern.
PS: I read somewhere that witches don't wear knickers. It gives them a better grip on the broomstick. -
Since this makes Procoder work, should I stick with TMPGenc or should I go to ProCoder?
I am capturing Hi8 at 368x480, resizing to 344x480 and padding out to 352x480 in VD them frameserving to TMPGEnc for Half D1 VBR.
This works pretty well since all the footage is very clean. I've eperimented with clears and other filters and see no noticable difference so just encode directly to Half D1 as is.
I saw in other posts that ProCoder creates a image closer to teh original then TMPGEnc does. Is it worth the switch and how much faster would PC be then TMPGEnc? Should I use 1.5 or 2?
LS -
All I get is this:
Script error: syntax error
(D:\video.avs, line 1, column 5)
/////////// NEVERMIND //////////////
I re-ran AUXSETUP again, re-installed frameserving, works fine now. Encoding away.Want my help? Ask here! (not via PM!)
please ask in a new thread - or do a search here as that has been covered many times ...
Will Avisynth 'Directshowsource' Produce Reduced Quality in Frames Served?
By Chakra in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2011, 09:25 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Error frame 0 in VirtualDubMod
By rocky12 in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2009, 17:06 -
MPAA gets served with DMCA take down notice
By kosekjm in forum Latest Video NewsReplies: 6Last Post: 4th Jan 2008, 23:22 -
How do I edit the frame rate of a selection of frames in VirtualDubMod?
By manilow in forum RestorationReplies: 4Last Post: 21st Dec 2007, 22:12
