this is a bit of a strange question but im hoping someone here can help, i have just backed up a few dvd's, i am using nero 6 for this and make an image of the disc and then copy to a blank disc, this is all automatic, the the disc image is placed on my slave hard drive, this is completley blank, but since i have copied a few discs i have noticed that it now says the 11.7 gb is being used on the hard drive, i have examined the drive and cant see anyting is on it, i have also defragged thr drive and its still says the same, if i carry on then a few more discs and the hard drive will be full as its only 40gb, yet the drive shows as blank when i explore it, please please please can someone help or recoomend somewhere i can post this in another forum that might help,
Regards Pete![]()
Maybe Norton Protection is turned on, if you have that. Or the recycle bin for that drive needs emptying?
Try right-clicking the HD in Explorer, and go to Properties. Then do a "Disc Cleanup" on it. See if tha helps.
If you'd like, I can move this thread to the Computer forum. You will probably get more knowledgeable answers there
tools>folder options>view...click on to show hidden files and sort through those, might be able to find what your lookin for
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
i dont believe it, i looked in norton and for some reason the slave drive was set to protect files, i unset it, then used the unerase option to recover the discs images back onto the drive, i then deleted them from there and hey presto, i have my hard drive back again, i will keep a check on it but thank you very much for the suggestion
Sweet!Originally Posted by pete7769
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
RCA DRC8030N 80GB Recorder play back of hard drive
By katorigin in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jul 2010, 11:11 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Advice on Hard Drive Back Up
By King Otoss in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 06:35 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03
