Results 1 to 9 of 9
  1. HELP !! i cant get this thing working ..??
    Everything installs smooth and i have located all the path names for the supporting files .. CCE 2.5 Ect...
    and i get an error every time
    Runtime error 76 Path not found..
    It gives me this error when it gets to Phase 2 Encoding
    Creating m2V for VTS_04
    I hope someone can help....
  2. Post the Rebuilder log, REBUILDER.ECL, and ITEM.ECL
  3. i cant find the log file ?? i would have thought that it was in the program folder where rebuilder is at but its not...
  4. OK now i have a totally different problem..
    After remapping all the needed files to rebuilder it seems to work, But ...... when it gets to Encoding.. well this is what it says.
    Transcoding...
    [18:32:11] Phase I, PREPARATION started.
    - VTS_05: 150,862 sectors.
    -- Scanning and writing .D2V file
    -- Processed 11,281 frames.
    -- Building .AVS and .ECL files
    - VTS_06: 31,290 sectors.
    -- Processed 2,424 frames.
    - VTS_07: 134,071 sectors.
    -- Processed 10,000 frames.
    - VTS_08: 2,448,245 sectors.
    -- Processed 175,530 frames.
    - VTS_09: 388,226 sectors.
    -- Processed 36,081 frames.
    - VTS_10: 138,985 sectors.
    -- Processed 10,367 frames.
    - VTS_11: 142,196 sectors.
    -- Processed 10,598 frames.
    - Reduction Level for DVD-5: 55.4%
    - Overall Bitrate : 2,367Kbs
    - Space for Video : 3,087,872KB
    - HIGH/LOW/AVERAGE Cell Bitrates: 3,277/100/2,367 Kbs
    [18:36:51] Phase I, PREPARATION completed in 4 minutes.
    [18:36:51] Phase II ENCODING started
    - Creating M2V for VTS_05 segment 0
    - Creating M2V for VTS_05 segment 1
    - Creating M2V for VTS_06 segment 0
    - Creating M2V for VTS_06 segment 1
    - Creating M2V for VTS_07 segment 0
    - Creating M2V for VTS_07 segment 1
    - Creating M2V for VTS_08 segment 0
    - Creating M2V for VTS_08 segment 1
    - Creating M2V for VTS_08 segment 2
    - Creating M2V for VTS_08 segment 3
    - Creating M2V for VTS_08 segment 4
    - Creating M2V for VTS_08 segment 5
    - Creating M2V for VTS_08 segment 6
    - Creating M2V for VTS_08 segment 7
    - Creating M2V for VTS_08 segment 8
    - Creating M2V for VTS_08 segment 9
    - Creating M2V for VTS_08 segment 10
    - Creating M2V for VTS_08 segment 11
    - Creating M2V for VTS_08 segment 12
    - Creating M2V for VTS_08 segment 13
    - Creating M2V for VTS_08 segment 14
    - Creating M2V for VTS_08 segment 15
    - Creating M2V for VTS_08 segment 16
    - Creating M2V for VTS_08 segment 17
    - Creating M2V for VTS_08 segment 18
    - Creating M2V for VTS_08 segment 19
    - Creating M2V for VTS_08 segment 20
    - Creating M2V for VTS_08 segment 21
    - Creating M2V for VTS_08 segment 22
    - Creating M2V for VTS_08 segment 23
    - Creating M2V for VTS_08 segment 24
    - Creating M2V for VTS_08 segment 25
    - Creating M2V for VTS_08 segment 26
    - Creating M2V for VTS_08 segment 27
    - Creating M2V for VTS_08 segment 28
    - Creating M2V for VTS_08 segment 29
    - Creating M2V for VTS_08 segment 30
    - Creating M2V for VTS_08 segment 31
    - Creating M2V for VTS_08 segment 32
    - Creating M2V for VTS_08 segment 33
    - Creating M2V for VTS_08 segment 34
    - Creating M2V for VTS_08 segment 35
    - Creating M2V for VTS_08 segment 36
    - Creating M2V for VTS_08 segment 37
    - Creating M2V for VTS_08 segment 38
    - Creating M2V for VTS_08 segment 39
    - Creating M2V for VTS_08 segment 40
    - Creating M2V for VTS_08 segment 41
    - Creating M2V for VTS_08 segment 42
    - Creating M2V for VTS_08 segment 43
    - Creating M2V for VTS_08 segment 44
    - Creating M2V for VTS_08 segment 45
    - Creating M2V for VTS_08 segment 46
    - Creating M2V for VTS_08 segment 47
    - Creating M2V for VTS_08 segment 48
    - Creating M2V for VTS_08 segment 49
    - Creating M2V for VTS_08 segment 50
    - Creating M2V for VTS_08 segment 51
    - Creating M2V for VTS_08 segment 52
    - Creating M2V for VTS_08 segment 53
    - Creating M2V for VTS_08 segment 54
    - Creating M2V for VTS_08 segment 55
    - Creating M2V for VTS_08 segment 56
    - Creating M2V for VTS_08 segment 57
    - Creating M2V for VTS_08 segment 58
    - Creating M2V for VTS_08 segment 59
    - Creating M2V for VTS_08 segment 60
    - Creating M2V for VTS_09 segment 0
    - Creating M2V for VTS_09 segment 1
    - Creating M2V for VTS_09 segment 2
    - Creating M2V for VTS_09 segment 3
    - Creating M2V for VTS_09 segment 4
    - Creating M2V for VTS_09 segment 5
    - Creating M2V for VTS_09 segment 6
    - Creating M2V for VTS_09 segment 7
    - Creating M2V for VTS_09 segment 8
    - Creating M2V for VTS_09 segment 9
    - Creating M2V for VTS_09 segment 10
    - Creating M2V for VTS_09 segment 11
    - Creating M2V for VTS_09 segment 12
    - Creating M2V for VTS_09 segment 13
    - Creating M2V for VTS_09 segment 14
    - Creating M2V for VTS_09 segment 15
    - Creating M2V for VTS_10 segment 0
    - Creating M2V for VTS_10 segment 1
    - Creating M2V for VTS_11 segment 0
    - Creating M2V for VTS_11 segment 1
    [18:36:55] Phase II ENCODING completed in 0 minutes.
    [18:36:55] Phase III, REBUILD started.
    - Copying IFO, BUP, and unaltered files...
    Rebuild aborted.
    Did you notice that encoding didn't even take a minute ?? And it aborted because at phase III it says theres nothing to rebuild..?? it says to trans-code and prepare first ??
    Any help would be great..
    Thank you in advance
  5. Member daamon's Avatar
    Melbourne, Oz
    Hi geekman28,
    Because you're using DVD Rebuilder, I'm guessing you're trying to backup a DVD from DVD9 to a single DVD5 (you don't actually say what you're trying to do...).
    Based on that, I'd suggest ripping with either DVDDecrypter and / or Smart Ripper (when one doesn't do the job, the other usually does) and then using DVDShrink.
    All freeware, all reliable all good software. No need for CCE or TMPGEnc.
    Hope that helps. Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    try posting your problem at the dooms9 forum site they have a DVDREBUILDER SECTION.
    http://forum.doom9.org/forumdisplay.php?s=9e84b592f65f44877bc05c0582fee22b&forumid=75
  7. Thanks for the tip ... I will Post overthere and see what i get
    Jun 2004
    Argentina
    Check the version of MPEG2DEC3DG.DLL you are using. It should be 1.0.1.0. Check also the date (I do not remember the correct one now, please verify in the doom9 forum indicated above)
    Post the content of your Rebuilder.ini file
    Newbie to DVD backup
