I am looking for software that will convert vob to mpg.
Also, all the vob files that make a movie are in one directory per movie. Is there a program that will convert all that is in the directory to a mpg movie?
best regards
VOBs consist mainly of mpg video, so there's no conversion needed. ReJig is one of many apps that can demux the mpg out of a (series of) VOB(s)
/Mats -
And if you want separate video and audio streams, Vobrator.
Otherwise try renaming the FILENAME.VOB file to FILENAME.MPG. Then open and edit. This doesn't work with all apps, but many will open it as-is
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
VOB to MPG - What to use?
By Thingy in forum Newbie / General discussionsReplies: 11Last Post: 24th Apr 2010, 17:18 -
VOB to MPG
By marbletravis in forum DVD RippingReplies: 2Last Post: 24th Apr 2008, 12:40 -
Problem with .VOB to .MPG
By SilverFalcon in forum Video ConversionReplies: 2Last Post: 30th Jul 2007, 14:27 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
