Does one exist? I've tried looking in the search engine but couldn't find one.
If a reasonably priced one doesn't exist I was going to get one without the conversion capabilities for around $300. Can anyone recommend a good dvd recorder? Might there be better models to choose from at better prices down the road in say six months time?
Results 1 to 12 of 12
On the input or output. Actually I can't help with either but if you specify which you mean you might get more helpful repliesOriginally Posted by LVSaint
Just a thought
The ability to play both formats but a video converter that will convert on the fly PAL into NTSC to play on standard US tv.Originally Posted by bugster
That sucks. There are several players that'll do including the Philips 642 which I may have to get in addition now. Does anyone know if there are any plans to release a multisystem recorder in the future?Originally Posted by zorankarapancev
Best bet is probably to get a multi-system TV. Not sure how easy that is in the USA, but most TV's sold in Europe are multi-system even if they do not advertise the fact.
They do exist but we have a large screen projection tv which can't be replaced. The $60 additional PAL playing dvd player is a much better option. Ok then, two units it is then. Cheers for the help.Originally Posted by bugster
Wait a minute...a Liteon DVD Recorder can convert an OUTGOING signal from one format to the other can't it?
It just cant RECORD an NTSC signal in PAL...or vise versa.
That is what I've read.
https://www.videohelp.com/dvdplayers.php?DVDnameid=3507&Search=Search&#comments -
PAL disc on NTSC system can be NTSC50 out
Will play, but not true NTSC
NTSC disc on PAL system can be PAL60 out
Will play, but not true PAL
If this is all you need, grab a Cyberhome player. The LiteOn DVD recorder is quite honestly the VERY BEST player I've ever used for playing PAL on NTSC tv.
**edit: I had my PAL60 and NTSC50 in the wrong places. Fixed now. Same thought process, same meaning. This is why I hate tech terms.Want my help? Ask here! (not via PM!)
Doesn't the JVC DR-M10S output NTSC for PAL discs? I think someone tried this but not 100% sure.
My JVC player does convert PAL discs to true NTSC output. -
Yes, it does. I think it is part of LSI chip function. But you have to take care of regional code first.Originally Posted by Lucien
See there...that'll learn me for actually believing those comments people put on there..Originally Posted by lordsmurf
Thanks Smurf for the clarification.
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
dvd recorder that records PAL and NTSC
By ecc in forum DVD & Blu-ray RecordersReplies: 4Last Post: 8th Jan 2009, 03:53 -
Pal/Ntsc DVD Recorder question
By ArtieEngh in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 11:18 -
How to record NTSC on a PAL dvd recorder?!
By Dekaspace in forum Newbie / General discussionsReplies: 8Last Post: 4th Jul 2008, 00:21 -
is there any PAL to NTSC DVD converter?
By mvp in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2007, 00:38
