Hi,
I'm using DVDAuthor and writing my own xml file. I have two menus, but I can't work out how I get one title to go to the second menu at then end (in its post command). It seems "jump" doesn't work, and I can do "call menu" which goes to the first menu, but not "call menu 2", or "call menu2".
Anybody know how this works?
thanks
Dave
https://www.videohelp.com/guides.php?link=686
This guide has samples of XML code for DVD Author -
Thanks.
From what I can work out from that, there's no way for a post command to go back to anything other than the initial menu, but you can set a variable so that when it goes back to the initial menu it can immediately jump to a different menu.
Stupid system DVD. -
You could enable jumppad, but the registry idea is the best approach. See my example.
https://www.videohelp.com/forum/viewtopic.php?p=961454#961454
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
DVDStyler (dvdauthor), need to jump title sets.
By bigstusexy in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 08:02 -
Question about auto jump to next title with Gui For DVDAuthor
By jimdagys in forum Authoring (DVD)Replies: 6Last Post: 26th Nov 2008, 02:55 -
Panasonic DMR-EA18K - Title Jump
By pannayar in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Aug 2008, 23:56 -
Dvd Author Ignoring jump chapter n in title pre commands (no errors)
By FallenAngel10 in forum Authoring (DVD)Replies: 0Last Post: 7th Jul 2007, 16:04
