I'm encoding some home movies from DV to cut onto a DVD. Most of the movies are between 70 and 80 minutes long. I started by using the tried and trusted iMovie -> iDVD route but, as the DVDs are bigger than 60 mins, this only allows me to use the 'Highest Quality' encoding setting which results in aggresively compressed files of around 2.5 GB.
My perception is that the highest quality possible would result in a file size of 4GB. Is there any advantage in encoding the .mov from iMovie (in dv format) using ffmpegx with a bitrate that is calculated to 4GB even though it shows up as 'blue' in the rate calculator window.
Supplementary question - which mpeg2 encoder gives highest quality, and on what settings?
In variable bitrate mpeg-2 encodings, the bitrate will vary by itself depending on the movie complexity, so using "blue" bitrates should not improve quality.
The highest visual quality is achieved with ffmpeg, though mpeg2enc has a better ratecontrol and is more compliant to DVD standards. So there is no absolute winner.
About settings, "quick preset" settings should be used.
A ffmpegX's problem about setting the audio bitrate
By lzero1319 in forum ffmpegX general discussionReplies: 1Last Post: 7th Apr 2012, 09:44 -
Jittery movement on encoded file (Bitrate setting question)
By cb678 in forum ffmpegX general discussionReplies: 4Last Post: 5th Nov 2011, 15:30 -
MKV to AVI Video Bitrate Setting
By gonwk in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2011, 20:31 -
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 08:12 -
X264 video: Impact of resolution on quality
By sanosuke in forum Video ConversionReplies: 10Last Post: 14th Aug 2010, 15:30
