I posted in the canopus forum but just in case anyone here has seen this..
In procoder 1.5 I am trying to create two WMF files, one at 640kbps and another at low bitrate 30kbps .. for some reason, the total bitrate in procoder does not change even when I select the 30 kbps stream and try to use it to encode..the resulting file is the same size and shows as 640kbps in the windows media player...
this seems like a bug but maybe it's something I am doing wrong or maybe there's a workaround
anyone seen this before? TIA
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
well, I partly figured it out (to reply to my own post)...the 'system profile' was not selected, so it must default to a high bitrate...when I do select the profile (e.g. 28.8k dialup, etc.), it changes the overall bitrate properly..the selected profile is not shown for some reason, but at least I think I see why it's happening...
Bitrate MKV Problem
By turbogt16v in forum Video ConversionReplies: 3Last Post: 27th Sep 2011, 04:08 -
FFmpeg bitrate problem
By ajitpals in forum Video ConversionReplies: 0Last Post: 1st May 2010, 02:02 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 13:47 -
Procoder NTSC Conversion Problem
By spliffy in forum Video ConversionReplies: 17Last Post: 10th Feb 2008, 08:06 -
MP3 Bitrate problem
By efiste2 in forum AudioReplies: 8Last Post: 25th Sep 2007, 19:59
