Well, I've been using Winavi and I must say that I was amazed with the simplicity and efficiency of this software. I only had problems with burning, but I'm using Nero to burn the video files. I heard that dvdSanta produced higher quality movies, but, as far as I know, it doenst have the DirectAC3 technology, which is a really amazing feature of Winavi. Am I right or dvdSanta also has better audio quality?
Despite the simplicity of the program, I had some problems when I tried to make a Mr.Bean compilation. I had all the episodes in Xvid format. What I did was loading all the files into Winavi and them converting everything like any other video file. I changed the settings so that the result files could fit in 2 Dvd-R 4,7G disks. I also thought that the program would split the episodes into chapters.The result was somewhat strange. In the end, I got one directory called Disk_0 with 15 titles instead of 15 chapters. Then I went to Nero. The problem is that I only know how to burn files to fit in a single disk. How should I burn those 15 titles? I tried burning the first 8 into a dvd and it worked, but when I tried to burn the remaining ones I got a useless dvd. I really dont know what to do. In addition to that, I would like to have 15 chapters instead of 15 titles so i ask if there is any program that allows me to edit the files produced by Winavi.
Can anyone help me?
you could try reauthor with tmpgenc dvd author, click on add dvd video and choose the disk_0 folder.
Starting over with WinAvi problems
By alex0000 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2010, 05:30 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 13:10 -
WinAVI Audio Problems
By thegun in forum Video ConversionReplies: 7Last Post: 23rd Aug 2007, 13:50 -
Winavi 8.0 Help
By agkoichi in forum Video ConversionReplies: 1Last Post: 26th Jul 2007, 04:17
