I just burned my first DVD and plays fine on the DVD player. But the problem is, is it's not in color. It's in black and white and looks a little pixlated. Would anyone know a possible fix to this? Thanks!
How does it play/look on your computer? What are the details on the source file? How did you make your DVD? What software, methods or guide did you use?
If you give details we can help figure out where you might improve your product."Art is making something out of nothing and selling it." - Frank Zappa -
Hi ldham,
Where are you in the world? Hint: Update your profile...
The reason I ask is that it sounds like it could be that your DVD player and / or TV don't play PAL, as I'm guessing (statistacally for this site) that you're in the US or thereabouts (also based on the time your posting...).
If that's the case, you need to re-do everything you've done exactly the same except use an NTSC template.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Yeah, I figured it would be the PAL since I have an NA DVD player. Thanks for your help guys!
Oops, my mistake! Sorry
La Linea by Osvaldo Cavandoli
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
