hey guys. i have 28 .avi videos that i want to put on 1 dvd-r.. together they are 3.91GB so im sure it could work.. of course i want to be able to select each one, so im gonna need a menu... how am i going to do this? GSpot info..
http://img.photobucket.com/albums/v281/a1rflow/Untitled-1.jpg
You are in breach of the forum rules and are being issued with a formal warning. No Warez, including TV episode downloads: http://www.allouttoons.com/familyguy/episodes.shtml
/ Moderator Capmaster
Closed Thread
you want them in DVD-Video format on that DVD-R? Then I suggest you are not going to be able to do it. At the moment your files are in compressed xvid format. To get a decent MPEG2 format for DVD-Video you would need to go at least 3 times the bitrate you currently have and therefore 3 times the filesize (all approximate numbers).
I'm also guessing you have somewhere around 10 hours of AVIs?"speed's just a question of money. How fast can you go?" - Mad Max, 1979
28 videos X 22 minutes each = about 10 hours
To get 10 hours on a DVD encode your avi's to mpeg using an audio bitrate of 128 kbps and video bitrate of about 850 kbps. You should use VCD resolution (352x240/288) for bitrates that low. Use any authoring program to make the menu."Art is making something out of nothing and selling it." - Frank Zappa
u can cram all of em on 1 disc if u want. get tmpg dvd source creator. it lets u select for example 6 videos and adjust the compression to have optimal quality for your amt of videos. i cant reccomend u try to put all 28 episodes from seasons 1 and 2 on 1 disc because that in violation of forum rules, plz discuss your piracy goals elsewhere
28 Avi x 23 Min each = 644 Minutes. You CANT get all that onto 1-DVD. Your bit rate will be like 700 which is really low, lower than VCD. Quallity will look really crappy if you do that. You choice would be put onto 2-DVD.
Useless you go find a DVD Player that can play AVI files, then you just burn it as data(This will fit all onto 1-DVD).
I know a way to put 75 episodes on a single DVD. But it won't be high quality (though not "crap" either) and it won't play on many players.
Possible, but not smart.Want my help? Ask here! (not via PM!)
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 8Last Post: 10th Jan 2026, 15:42 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
How to make a compilation of 4:3 videos and 16:9 videos together on a dvd?
By pedrotc2002 in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2010, 18:35 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13 -
16:9 and 4:3 Videos In Same DVD
By urdivine in forum Authoring (DVD)Replies: 7Last Post: 8th Oct 2008, 09:30
