Hey guys, i got a taped DV of a birthday party to DVD, but it aint been edit. Whats the best program out there for this? Doesnt even have to be the best, just that some parts of the movie need to be cut outThanks guys SasArchiver
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights -
Here's the procedure that I use to cut out parts of an mpeg that is fast and easy:
1. Download and run your mpeg through demux, found here:
http://www.geocities.com/ted_rossin/tools/Video/Video.html
This will split your mpeg file into 2 files, m2v and mp2. If you get a different format other than mp2, convert it to mp2 with either BeSweet GUI or FFMpeg.
2. Import your mp2 and m2v files into MPEG2Schnitt (you can also use cuttermaran, but it needs TMPGENC so you can only use it for 30 days). This will let you cut out the parts that you don't want. It will then export new m2v and mp2 files without rendering! You can then use these with whatever DVD Authoring program you have, or GUI for DVD Author, which works great. You may have to remux them, so you can use mplex, or just search around in the tools section.
This may sound complicated but it really is quite easy, so give it a try. Good luck!
thx for ur reply. yeah thats sounds quite straight forward..ive done video stuff before but not the editing part. Need names etc coming onto the screen, what u use for that??
As far as free windows software, I use Windows Movie Maker 2. Its only for XP, but its free and you can download it at Microsoft.com. The only thing about Movie Maker is that it only exports in wmv format, so you will have to convert it, but I can help there too.Need names etc coming onto the screen, what u use for that??
1. Take the exported wmv file and import it into Stoik Video Converter. This will let you convert it to avi (you probably want to use the XviD video codec, see www.xvid.org ).
2. Take your avi file and either use BBMpeg, The Film Machine, SVCD2DVD, or TMPGENC if your trial hasn't run out and convert your file to mpeg 2 dvd format.
Any other questions, just ask!
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 06:08 -
Virtualdub - Edit without re-encoding (except at edit point)
By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 06:59 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13
