    Jul 2004
    Italy
    So I used DVDshrink. Unfortunately at the end of the backup process Nero diddn’t start and a message appeared:
    File” Oceab_Eleven_2001.ISO” is above 2 GB, therefore it cannot be memorized in a file system ISO. Ufile system UDF to write a file of these dimensions: You should select another type of compilation
    What does it mean? What shall I do?
  2. Look to the left under HOW TO, Convert for DVDShrink guides
  3. Hi Marlo,
    You are using the FAT32 file system (most probably with Win98/Me) and there's a file limit of 2 gig. Upgrade to Win2000/XP and use NTFS, and the error will disappear.
    Good luck,
    Dan
    Jul 2004
    Italy
    no, no I have XP and NTFS
  5. Banned
    May 2003
    Massachusetts
    What version is your Nero?
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Use DVD Decrypter to burn unless you have to change the structure after shrinking
    Read my blog here.
    Jul 2004
    Italy
    Nero is the last version available. With dvd decrypter it works. I don't understand......
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Sounds like Nero is trying to write the ISO as a data file, on an ISO file system DVD, not writing the ISO...
    /Mats
