Results 1 to 15 of 15
In future you would be better off doing the editing before converting to MPEG, Virtualdub is ideal. I've never used this but it should work - using TMPGenc click file>MPEG tools and select multiplex and mux your mp2 and m2v files. Then use the merge and cut function to edit.
He's a liar and a murderer, and I say that with all due respect. -
mpegvcr from womble is great for editing mpeg files. There is a guide on how to use it on http://www.digitalfaq.com/. You can download a fully functional trial copy thats good for about 30 days to see if you like it. Sometimes using the tmpgenc method gave me aucio video sync issues but I have never had a/v sync issues with mpegvcr.
Donadagohvi (Cherokee for "Until we meet again") -
You definitely want to do all your editing before mpg conversion.
jeanl -
If your editing comprises simple cuts and joins, and you have an application that will allow you to do this accurate to the frame, then you may not see any loss, as there may not be a need to reencode very mcuh if at all (there will probably be some reencoding to make sure GOPs remain correct)
If you want to use a more powerful editor that does not give you frame accurate edits, or want to add overlays, fades and other effects, the mpeg-2 is not the best medium to work in.Read my blog here.
Actually I have still format before I encoded to MPEG2 so I can still do editing that way.What tool should I use than??
Richard -
Originally Posted by freebird73717
I get a error message like
You are not authorized to view this page
You do not have permission to view this directory or page from the Internet address of your Web browser.
HTTP 403.6 - Forbidden: IP address rejected
Internet Information Services
And I'm wondering if it is blacklisting at their end or my end?
I'm on Verizon DSL right now and their site could be blacklisting me, Never neem their of course, or maybe error message isn't right and it has been blocked by Spybots blocking or Spyware Blaster's blocking action.
So just curious, as I'm always looking for new forums to kill those slow moments here at work.
Thanks -
Try this link
http://www.digitalfaq.com/Donadagohvi (Cherokee for "Until we meet again") -
TMPGEnc MPEG Editor is also frame accurate, only re-encodes necessary frames around the edit point to maintain GOP structure. It does call home periodically to renew the license so internet connection is needed. I've used it for a couple of projects with good success.
maybe it doesn't like XP-SP2?
Looking again I see I missed the extra . (DOT), in http://www.digitalfaq.com./ in the original link. I'm not sure what that does in HTML of course.
OH Well, Thanks a lot.
Cheers
RT -
That dot in the original link of my first post was just the ending period of my sentence. I think that was what messed up the link in the first place. The period got added to the link when it shouldn't have.
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
InFanView How do I edit size and get it to print the edit
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2008, 10:51 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
