hi, you can actually do a screen capture from windows media player using Hypersnap-DX.
Make sure the following setting is set when you want to do the screen shot.
under "Capture"---> "enabled special capture" --> make sure to tick all boxes.
then use "scroll lock" to capture the screenshot
Closed Thread
Results 61 to 90 of 133
Capture Professional screen capture software can capture images from many media player applications. The fundamental issue is that most of these applications use DirectX overlays, which only render when the windows display has black pixlels beneath the overlay. This is why the print screen key and many other screen capture applications capture black areas instead of the intended video. Capture Professional queries each application for its overlays and extracts them. You will want to use the DirectX screen capture operation (default hotkey - CTRL + SHIFT + X) to capture these overlays. A 30 day trial is available.
Capture Professional can also be capture video from a playing video using the Include DirectX Surfaces... option and any other screen capture operation. Using this option while capturing video may result in a large number of dropped frames due to the amount of time required to capture each individual video frame.
You may also get some results by disabling all video acceleration which may eliminate the overlay usage. However, playback may be bad and this option may not work/be available for all media player applications.
There may be legal issues using captured copyrighted materials.
what did you mean ? just capture a image from a video?
i am using ACA PRO ,it can capture anything on your screen including all kind of video.
Hi new to the forum...back to the topic.
option1::When capturing image from DVD's I use PowerDVD. I have one problem though I can't seem to find the clipboard (or wherever it stores the images once you start clicking). What I do is I paste each image to MSpaint.. Troublesome..Anyway, someone point the way please...
option2::I vote for Image Grab. It's very easy to use. Go to the website to learn more about it. The intsructions are newbie friendly. Oh the program is available on Tools section, click here >>ImageGrab(>_<)
option3::I read in here that you can use Windows Movie Maker. Never tried it though. Check it out.
The quality of BMP is good, but also the file size is also... wah
please help, my PowerDVD does not do the capture thing, i have the camera picture, but when i click on it the word, "capture" appears on the video screen, but nothing happens, I right cliked on the camera icon, and it has options, there that i tryed to reselect, but it still doesn't do anything, why?
I think PowerDVD captures to the clipboard? Capture, open Paint or other gfx edotor, and Paste.
/Mats
That sir is correct. However, be warned that the capture may not be of the correct aspect ratio (16:9 on my copy of PowerDVD 4 captures at 4:3, forcing me to stretch it after I paste it into Irfanview).Originally Posted by mats.hogberg
If you open the configuration in PowerDVD go to general>advanced>capture .... you can select how the captured image is handled, either to the clipboard or a file. You can also selct the aspect, the reson your the aspect is incorrect is because it's sizing it according to the video resolution. 16:9 and 4:3 both use the same resolution for DVD.
Originally Posted by BaldrickUsing VirtualDubMOD's (or VirtualDub-MPEG2) to save image sequences is a process I'm using for several file types and I love it. I am having my issues with VOB files though - the aspect ratio of the saved images is screwed up. I can get the program to open and preview the DVD files correctly (using the setting under preferences) but the saved images themselves do not have the correct dimensions.Originally Posted by mats.hogberg
Is there any way to do get images with the correct aspect ratio without ripping the files from the DVD first? Using a filter or some setting?
Thanks.
The resolution and aspect do not match, for example 720x480 is a valid resolution for 16:9 and 4:3. I don't use Virtualdub that much but it's probably giving you image sizes that are the same as the resolution. Use a batch image resizing tool like irfanview to resize them.
They should look OK if you use the resize filter (Lanczos3) in VDub to the correct AR (4:3 or 16:9)
/Mats
the version of Realplayer I have is 10.5 and it is said it dose screen shots but I can't find the tool/ itcon any where.
and I can't seem to download the Power Dvd softwear.
I didn't have time to see if anyone recommended this or not, but VLC has a capture that is pretty good.
Holler me answers on yahoo messenger would ya?
Hi There..
In a previous post on this thread, Johns0 says:
"If you want to capture a pic with windows media player then go to control panel/display/settings/advanced/troubleshooting and turn down hardware acceleration to none and then press Prt Scrn on your keyboard and paste from paint"
Why do I have to set the HW acceleration to none? how does the HW acceleration effect a screen capture on windows media player?
thanks
Hardware accelerated video is diplayed using overlay, which can't be captured using Print Screen.
/Mats
I'm having a bit of trouble learning how to save a single particular frame into an image. I have tried VirtualDub and it works great for saving the entire video into screenshots, but there doesn't seem to be a feature to save a single frame. The easiest way I have achieved this is to manually delete every last frame that isn't the one I want. There has to be an easier way!
I tried other suggested programs like Media Player Classic and it works great for saving particular frames, but there doesn't seem to be any ability to look through a video frame by frame like you can in VirtualDub. Is there something I'm missing? Thanks!
There is. Go to the frame you want, click "Video", then "Copy Source Frame to clipboard". Then open your favorite graphics editor (or even MS Paint) and Edit/Paste.Originally Posted by Seph"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
For some reason or another it doesn't seem to decode these new MKV files that well. Anything else that might be better than VirtualDubMod for that? I tried that AviDemux, but I couldn't get it to do what I wanted. It says that the file is H264 and that it won't be able to render all the frames accurately. Why not? It also asks to build some kind of index. I never thought it could be this difficult!
One of my most popular websites is a gallery of screen captures. I've just begun buying Blu-ray discs and have an LG combo drive, and I need to find a way to get screen captures from Blu-ray discs. The basic question is how can it be done?
I assume I will probably have to rip the disc and get into the files themselves to get a full-res full-size capture, so it won't be as easy as pressing a key.
I'm also willing to settle for lower resolution captures, just as long as I get something.
I've run across news stories (circa July 2006) about an OEM version of WinDVD that was able to get screen caps of high def discs, until they released a patched version that no longer allowed it, but I've been unable to find out which version, let alone find a copy.
Any ideas or leads would be greatly appreciated.Steven Hill at http://shillpages.com
With Vista, a 'quick and dirty' way to 'capture' a photo playing on your computer monitor is to pause the video and use Vista's 'Snipping Tool' to frame the portion you want as your still. Snipping Tool allows you to Copy the snip, or Save it as either JPG, GIF, or PNG. Really handy.
John Hanley
Sugar Land, TX
Video Editing - Embed motion video into Still Frame/Photo?
By staticGenerator in forum EditingReplies: 2Last Post: 4th Apr 2012, 19:54 -
photo capture from video signal hardware
By huegel in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 10:50 -
Photo analysis of file creation
By hellybelly in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2010, 11:14 -
If I have a video capture file that is 8 gb
By pugvader in forum EditingReplies: 21Last Post: 1st Jan 2009, 23:42 -
Legal Question regarding Copyrighted Audio on Video Photo DVD
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2008, 12:40
