  1. Hi,
    I just assembled my new system and run into this problem. The BIOS sees the SATA drive as 200GB but Windows sees only 131 GB.
    I installed the XP Pro on the drive upon booting from the CD.
    Any help would be greatly appreciated.
  2. Make sure you have at least XP SP1 installed.
  3. Is this the only reason for this problem or I should check something else?
  4. Banned
    Sep 2004
    Inner Circle of Thought
    It is the main reason.
  5. Have you got XP SP1 installed or not
  6. Banned
    Sep 2004
    My guess is that he doesn't.
  7. Member 888888's Avatar
    Jan 2004
    Turdistan
    I heard it was SP2. Weird.
  8. Originally Posted by 888888
    SP2 includes the required mods too. But SP1 is sufficient to support HD's greater than 130Gb.
