  1. Member RickTheRed's Avatar
    Aug 2004
    Up north
    According to my search in this forum, Nero can allow me to burn simultaneously with 2 burners.
    I have tried almost everything and I was never able to select multiple burners.
    Where is this?
    So far, I have used two instances of DVD decrypter to burn the same file at the same time and it worked well, but I prefer using Nero with ISO files.
    Apr 2003
    Maryland
    When you get to the burn screen you will see a little box that you check X for multiple burners
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. Member RickTheRed's Avatar
    Aug 2004
    Up north
    According to the above link, Nero will not let me burn to multiple burners if I have the OEM version.
    Now I guess that I have the OEM version (bundled with the burner when I bought it).
    What's funny is I have purchased two burners, both bundled with Nero.
    Gee, I hate those things. Why so many versions that I don't even know what I have?
    That little box is nowhere in my software.
    Thanks. I will use two instances of decrypter
