hi, i am making a vcd of all my bands crappy videos from a dvd i made before, i'm not new to this but i am having one problem.
i am encoding with tmpgenc and using a MVBR to keep the size down so it fits on a cd (upper 1150 lower 1000) - anyway, they come out looking good and all 20 videos fit onto the cd-r - i want to put them up for download but there's a problem with the timecode on each file - even though they last over three minutes each, when i play them in windows media player they come up at any length under a minute despite playing for the entire duration.
is there anything i can do to reset the timecode and make it look the correct length?
hope that makes sense. i'm forever having problems like this with the times looking considerably smaller than they really are - this happens also with some dvd files i create and causes many problems with authoring - i can work around those but this is very annoying, especially for those that download and watch on their pc.
thanks for reading.
cheers
mik x
ok, i've found that in tmpgenc if you search hard for some settings you can change the GOP settings to 1 instead of 2 (as mine must have been brokeninto 2 for some reason).
is there a program that lets you reset the GOP settings so i can avoid encoding all my videos again?
.m2ts / .sup timecode problem
By SpinyNorman in forum SubtitleReplies: 4Last Post: 13th May 2011, 17:33 -
Timecode skipping
By rds11 in forum EditingReplies: 1Last Post: 23rd Dec 2010, 09:24 -
No Timecode on my tape
By towarmforacoat in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 19:49 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
DVD Lab Pro timecode problem on Vista
By jonghyunchung in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 19:58
