I downloaded a mkv file, and googled quite a bit, but I've yet to find a utility that can take this and convert it to something I can burn and play on a dvd player.
I did find a program to play it on the pc, but I want to make a playable dvd from it.
Help?
Gary Tabar Jr.
Did you search these forums? try entering "mkv convert" in the search box ^^^^^
if you have installed matroska you should be able to convert with tmpgenc.
just search for mkv and you will get lots of tips like this
https://www.videohelp.com/forum/viewtopic.php?t=238859&highlight=mkv+d
and PLEASE don't post CONVERTING in the dvd author forum. -
Thanks for the assist.. but if you don't have a dvd image already and are converting one to make a dvd image, aren't you authoring a new one?
Where should a post like this actually belong?
(This looked like the only real forum topic that "fit"...)
I didn't install thsi format.. it's an image I was given a link to for an old obsure movie that isn't available in any form. The original author was kind enough to grab it for me, but he only uses his PC to play images he creates, and had no idea what I'd need to use to make a normal viewable copy for a standalone player.Gary Tabar Jr.
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
How Can I Convert .mkv files to any formart playable on normal DVD or PS3?
By shuyinliquid in forum Newbie / General discussionsReplies: 5Last Post: 20th Sep 2009, 12:27 -
convert x264 HDxT file to ps3 playable file
By yodaddi in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Mar 2009, 21:02 -
movies in WINAMP file want to convert to a playable DVD disk
By PBONNA in forum Authoring (DVD)Replies: 2Last Post: 3rd Feb 2009, 10:27 -
[Help] How could i convert a MKV into a PSP-playable video file?
By rustix in forum Video ConversionReplies: 4Last Post: 12th Jul 2008, 10:23
