Hi there!
Im a newbie and need some serius help here
Well, lets see... this is what I want to do:
I have a series of AVI episodes of an ANIME/MANGA series, and I want to open these movies one by one in VirtualDub and then cut the theme beginning and end of each episode. When the themes are gone, I want to join all of these episodes into one!
I know how to do this - Video>Direct Stream Copy and then, simply open the episodes, "set selection start" and "set selection end", and then "save as avi". I will do this with all the episodes.
Here is when I encounter the first problem... When I open some of the movies I get a prompt saying "VBR audio stream detected". When I open it with the VirtualDub including MP3 freeze it works fine. Then I do the same as above, I select the part that I want from the episode and then save it as avi.
Now is the biggest problem. When I try to join the edited episodes I cant, becose I get a prompt saying "Cannot append segment... The audio streams have different sampling rates (16000.00000 vs 15680.00000).
How can I make this work?! Please help me, and please describe it so that it is easy to understand (im a newbie ).
Closed Thread
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
Program like XenonMKV but with sampling rate conversion?
By shanghei in forum Video ConversionReplies: 1Last Post: 11th Nov 2011, 08:20 -
Understanding Video sampling rate
By Movie-Maker in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2008, 17:07 -
Transcoding Video - Bitrate, Sampling Rate etc Limits?
By Leo48 in forum Newbie / General discussionsReplies: 18Last Post: 22nd May 2008, 08:38 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09
