Hi there!
Im a newbie and need some serius help here![]()
Well, lets see... this is what I want to do:
I have a series of AVI episodes of an ANIME/MANGA series, and I want to open these movies one by one in VirtualDub and then cut the theme beginning and end of each episode. When the themes are gone, I want to join all of these episodes into one!
I know how to do this - Video>Direct Stream Copy and then, simply open the episodes, "set selection start" and "set selection end", and then "save as avi". I will do this with all the episodes.
Here is when I encounter the first problem... When I open some of the movies I get a prompt saying "VBR audio stream detected". When I open it with the VirtualDub including MP3 freeze it works fine. Then I do the same as above, I select the part that I want from the episode and then save it as avi.
Now is the biggest problem. When I try to join the edited episodes I cant, becose I get a prompt saying "Cannot append segment... The audio streams have different sampling rates (16000.00000 vs 15680.00000).
How can I make this work?! Please help me, and please describe it so that it is easy to understand (im a newbie).
Results 1 to 9 of 9
Set audio to full processing, no compression (LPCM) before saving the AVIs. That will give you big AVIs, but they'll all have regular WAV audio. Then you can join them, set audio compression to whatever you like (mp3?) and save out the AVI with all episodes.
/Mats -
What MP3 bit rate did you try? Or do the AVIs with WAV audio sound bad?
/Mats -
Det var WAV ljudet som blev brusigt när jag hade sparat i AVI med audio>full processing mode. Det brusade till i början av filmen och sedan hördes inget ljud alls i resten av filmen (prövade två gånger dessutom).
Please do not cross post. One topic is enough. Other topic locked.
/Moderator bugster -
Originally Posted by bugster
OK, demux audio: Audio -> Direct Stream copy, File -> Save WAV.
Rename ??? .wav to ???.mp3 (if the audio is in mp3 format in the original AVI)
Decode to WAV with GoldWave, or CDEx or... Make sure the wav sounds fine.
Load AVI back in. Select Audio -> WAV audio and your new wav.
Save out as AVI with new audio (File -> Save AVI)
/Mats -
Originally Posted by Salamence
Eac3to "Clipping Detected...2nd Pass" --> Avi2DVD finds no audio stream
By Murk in forum AudioReplies: 4Last Post: 5th Aug 2010, 16:27 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 08:01 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 10:12 -
VBR Audio detected
By timmer545 in forum AudioReplies: 16Last Post: 31st Mar 2008, 10:17 -
VBR Audio Stream detected
By luketheduke in forum Video ConversionReplies: 12Last Post: 8th May 2007, 21:17
