Hi!
I have an AVI file with AC3 audio, I have converted it to MPG2 with TMPGenc to create a DVD when I have imported on DVD lab the audio and video file I noted that the DVD result 4.7 Gb to calculate the exact bitrate I have used the calculator of the site, to reduce the file size I suppose I must reduce the bitrate but how to calculate it?
thanks in advance.
haltman
If your final authored size is too big to burn, you can use DVD Shrink to make it smaller.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
If I have understood right I must prepare the image to burn with DVD Lab and after compress with DVD Shrink is it right?
But in general what is the rules to calculate the right bitrate there is only one bitrate or I can choose one to optimize the size?
thanks haltman -
The size of an mpge file is determined by the playing time and the bitrate. To determine what bitrate to use to achive a particular file size for a specific playing time, use a bitrate calculator such as the one here .Originally Posted by The haltman
Note this is only good if you encode using CBR or n-pass VBR modes. In the VBR mode, the bitrate calculator determines the AVERAGE bitrate to specify. If you use quality based encoding methods such as TmpGenc's CQ mode, a bitrate calculator is of little use and determining the final file size in advance is very difficult and unreliable.
Also, don't forget to allow for the audio and allow a small overhead for DVD authoring data. -
So the better way may be to use the bitrate calculator from the site encode with tmpgenc create an image with DVD Lab and if is too big the result file compress it with DVD shrink.. a little long but possible..
Bitrate MKV Problem
By turbogt16v in forum Video ConversionReplies: 3Last Post: 27th Sep 2011, 04:08 -
FFmpeg bitrate problem
By ajitpals in forum Video ConversionReplies: 0Last Post: 1st May 2010, 02:02 -
AutoGK audio bitrate problem
By Mdoodm1000 in forum Video ConversionReplies: 5Last Post: 14th Aug 2009, 21:43 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53 -
MP3 Bitrate problem
By efiste2 in forum AudioReplies: 8Last Post: 25th Sep 2007, 19:59
