  1. I have a problem with the sun in my movies. Is their a program that can
    correct this problem. I was told that Nero has a section in their program,
    but I am not sure.
    USA
    Are you talking about lens flare, where the light reflects into the camcorder lens? A add on lens shade would help.
    For software, if the format is DV, look into Virtualdub. It has quite a few filters. For Virtualdub and DV you need a DV codec; the Pansonic DV Codec works for me.
