I've got an AIW 8500DV with the lastest MMC installed, everything works perfectly. I installed the DivX 5.2Pro codec and was doing some experimenting and noticed that you could only select the DivX5 pro codec if you set it to capture AVI and that the Audio MP3 settings suck (24KHz stereo at best) and you can't change the bit rate.
So I'm wondering if there is a way to install the Lame 3.96.1 MP3 codec (or whatever other codec) and use it in MMC 9.1 so I can capture higher quality audio.
I know I can capture DivX 5 with PCM audio and then later convert the audio to a hi quality MP3 later, then Mux them back together but that's a hassle and kinda defeats the purpose and convinence of real time capture.
Brian
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 02:24 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
