OK, I know the basics of a VCD > DVD conversion.
1)Extract the mpeg files from the VCD (I used tmpg's 'MPEG Tools')
2)Convert Audio to 48khz (ffmepgui)
3)Author DVD from m1v and 48khz audio (using TDA).
When I try this TDA gives me a GOP error on the video stream......do I ignore, or re-encode or is there a trick I should know? All I want to do is stick two or three vcd episodes into one full length DVD WITHOUT having to re-encode the video stream.
I thought DVD's could handle mpeg1 streams? I've not read anywhere about changing the GOP.......baffled.
Hi monzie,
What's the error? I'm guessing it's along the lines of "GOP is too long" or something to do with the "sequence header"...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Possibly, if your standalone DVD player will play them, but not guaranteed.
DVDs (generally) have to have a Group Of Pictures (GOP) no longer than 15 for PAL and 18 for NTSC (see "What is DVD", top left of the page for full specs).
Having not needed to cross this bridge, I'm not sure how you fix it. I'm guessing (unfortunately) that you'll need to re-encode and set your max GOP length as appropriate.
Check out Rejig, Womble MPEG-VCR among others.
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
incorrect GOP when trying to author DVD with files extracted from VCD
By ibzomie in forum Video ConversionReplies: 2Last Post: 20th Jan 2012, 10:58 -
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 23:34 -
i captured a video from reciever in .mpg format, [ a conversion problem] !!
By aSem-1 in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 17:22 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40
