HI CHRISSYBOY I NEED SOME HELP HER MAN. I HAVE NOT USED THE SVCD2DVD REGISTERED PROGRAM FOR A SHORT PERIODE OF TIME. SO I OPEN IT UP TODAY AND WAS GOING TO BURN A DVD.
WELL I OPEN IT UP AND I GOT AN ERROR WHILE THE PROGRAM WAS ACCESSING A FEW DLL FILES IN THE FOLDER I GUESS. THE ERRROR I GOT WAS A VERY LONG ONE BUT HERE GOES.
THE PROCESS CANNOT ACCESS THE FILE"C:\PROGRAM FILES\BADGERSOFT\SVCD2DVD\MSVCP.DLL" BECAUSE IT IS BEING USED BY ANOTHER PROCESS.
AT SYSTEM.I0._ERROR.WINIOERROR(INT32 ERRORCODE<STRING STR )
AT SYSTEM.IO.FILESTREAM..CTOR(STRING PATH,FILEMODE MODE,FILEACCESS ACCESS,FILESHARE,INT32BUFFERSIZE,BOOLEAN USEASYNC, STRING MSGPATH, BOOLEAN BFROMPROXY)
AT SYSTEM.IO.FILESTREAM..CTOR(STRING PATH,FILEMODE MODE,FILEACCESS ACCESS,FILESHARE SHARE)
AT _S_VCD2DVDMPG.21OFF09A7.0507E9097(OBJECT E0292B9ED559DA7D, EVENTARGS FBF34718E704C6BC)
AT SYSTEM.EVENTHANDLER.INVOKE(OBJECT SENDER, EVENTARGS E)
AT SYSTEM.WINDOWS.FORMS.FORM.ONLOAD(EVENTARGS E)
AT SYSTEM.WINDOWS.FORMS.FORM.SETVISIBLECORE(BOOLEAN VALUE)
AT SYSTEM.WINDOWS.FORMS.CONTROL.SET_VISIBLE(BOOLEAN VALUE)
AT SYSTEM.WINDOWS.FORMS.THREADCONTEXT.RUNMESSAGELOOPI NNER(INT32 REASON, APPLICATIONCONTEXT CONTEXT)
AT SYSTEM.WINDOWS.FORMS.THREADCONTEXT.RUNMESSAGELOOP( INT32 REASON, APPLICATIONCONTEXT XONTEXT)
AT SYSTEM.WINDOWS.FORMS.APPLICATION.RUN(FORM MAINFORM)
AT _S_VCDDVDMPG.210FF09A2516B1A7.MAIN(STRING[] ARGS)
I GOT A COUPLE OF TIMES THEN I DECIDED TO REMOVE THE PROGRAM AND RE-INSTALL IT SO I WENT TO THE REGISTERED PROGRAM SITE TO GET THE INSTALLER AND RE-REGISTER MY SOFTWARE AND USED UP MY SECOND INSTALL. NO MORE INSTALLS AND I HAVE STILL MAY HAVE TO REFORMAT MY SYSTEM.
HELP PLEASE IS GREATLY NEEDED TO USE MY PROGRAM AGAIN THANK YOU CHRISSYBOY IN ADVANCE.
Please turn off your caps lock
Thank you
sorry for the caps mate
here it is again
this time i was able to copy the message from the error message i got i even re-installed it and still same thing. i turned off all back ground programs and still same problem. i had recently installed sp2 and found it was not working properly with my system so i restored to a previous time without the sp2. maybe that is the problem? but anyways look at the error i got and you can maybe decode it to tell me what to do with it as i am no able to use it now
mscorlib error.
The process cannot access the file "C:\Program Files\BadgerSoft\SVCD2DVD\msvcp71.dll" because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at _S_VCD2DVDMPG.210ff09a2516b1a7.0507e45eec4e9097(Ob ject e0292b9ed559da7d, EventArgs fbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at _S_VCD2DVDMPG.210ff09a2516b1a7.Main(String[] args)
OK
It is a XP SP dll versioning issue. I have made a fix. Can you re-download the MSI file and try again, and do a reinstall?
Please let us know if it works or not.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Sorry I am getting back so late on this Chris but the job is done and no problems with it now. THank You Mate. Also when will version 2 be available for full release and will we have to redonate i guess you can say to get the newer version as well mate? Looking forward to seeing the new version
8)
Cannot start registered version
By itsonlyme in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th Jul 2011, 15:06 -
Is a new version of SVCD2DVD planned
By RJRobb in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 5th May 2011, 17:07 -
svcd2dvd not working with new MKV's
By Logical in forum SVCD2DVD & VOB2MPGReplies: 32Last Post: 21st Jan 2010, 16:27 -
Question about buying previously registered version of Vegas
By brassplyer in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2009, 11:12 -
Version 2.5.5000 (registered) Released 29 Nov 2008
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 30th Nov 2008, 03:55
