I was looking around at newegg.com and came across this monitor and it looks like a good deal, newegg usually does have good deals but this just seemed a little to cheap.
SLICK RICK....
Results 1 to 13 of 13
http://www.newegg.com/app/viewproductdesc.asp?description=24-021-010&DEPA=0
For what it's worth.If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
here's why:
Native Resolution: 1280x1024 (SXGA)
19" should be 1600x1280
Response time is slow too
Response Time: 25ms"Terminated!" :firing: -
Originally Posted by thayne
Is there really that much of a quality difference between those 2 resolutions? If it was only going to be used for regular everyday tasks and watching movies, not gamming. Would it not be a good choice for a monitor used for those purposes considering the price?
SLICK RICK....Originally Posted by lordsmurf -
Yeah there is. I'd get a 17" if you want 1280x1024 On a 19" it would look silly. Watching moving could be a problem with the response time, you'll see diagnal slices down the screen in fast motion scenes
General rule is:
15" LCD 1024x768
17" LCD 1280x1024
19-20" LCD 1600x1280
21" and above go higher and cost a fortune
I'd look for a response time of 16ms or less for movies watching"Terminated!" :firing: -
This is where I was checking some of the other monitors.
http://www.newegg.com/app/ViewProduct.asp?submit=property&DEPA=0
*Can't get the damn link to work*
for 19"??? Weak! Maybe I was thinking 21"
I'd go look at one in a store first to see if it looks okay to you. to me 1280x1024 is perfect for a 17" LCD.
You still prolly want a faster refresh time though"Terminated!" :firing: -
here's what you need! This one is 1600x1280 16ms
http://www.newegg.com/app/ViewProductDesc.asp?description=24-116-285&depa=0"Terminated!" :firing: -
I'd get this one if you want cheap
http://www.newegg.com/app/ViewProductDesc.asp?description=24-116-294&depa=0
I just bought a cheap monitor from newegg, CTX brand 17" CRT. The damn thing broke two months later. It was too late to get a replacement from newegg and it would cost me more in shipping to get it fixed under the manufacturer's warranty, than to buy a new monitor.
I usually avoid the deals that are too good to be true, because of what happens when deals are too good to be true. -
Housmate has a 19" 1280x1024, looks sweet to me. i'm used to 1024x768 on a 17", so it's pretty similar.
I just got a 19" 1920x1440. Replaced a 17" plasma that I'm giving to my wife's brother. I just built a new unit for him and had the extra monitor.
I can get this cheap. Questions on what I can do with it.
By GLE3 in forum Capturing and VCRReplies: 16Last Post: 16th Apr 2009, 20:40 -
need cheap mp4 player
By Shaorin in forum Portable VideoReplies: 6Last Post: 25th Dec 2008, 00:08 -
Scanners should I just buy a cheap one
By mikesbytes in forum ComputerReplies: 20Last Post: 13th Feb 2008, 10:44 -
Cheap-Ass stores... or is it just me?
By MeDiCo_BrUjO in forum Off topicReplies: 4Last Post: 1st Nov 2007, 09:24 -
Where to get DVD DL disks cheap?
By Jorge in forum DVD RippingReplies: 44Last Post: 21st Sep 2007, 09:38
