neither of my cd rom drives are being recognized by my computer so i want to reformat so that things can all be put right again. i have the reformat disc, but as the comp does not ever recognize that it is in the drive, that isnt much help. anyone know another way?
Some proprietrary machines (HP, Compaq, Dell) have a recovery partition that contains the OS & original software. If yours has this partition, you can do a recovery (format & install) from there. Otherwise, try to repair your OS with your install disc (this should reinstall your CD-ROM drivers). Or boot in Safe Mode (basic drivers only), if you can. I assume you can access the internet (you're posting from your machine)... try to find & install your CD-ROM drivers, as they're probably corrupt.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Originally Posted by Shocker Milwaukee
i have an hp xt936 with me - where can i find drivers for it? -
http://welcome.hp.com/country/us/en/support.html
one step further"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
They will be on your install/recovery disc for sure. Look into Windows Explorer. How many hard drives do you have? How many can you 'see' under Windows Explorer? If you only have one, but can see two hard drives (C: & D: ), then you probably have a recovery partition & can reinstall from there. Can you boot into Safe Mode? If so, can you 'see' your optical drive(s)? If so, reinstall from your disc in Safe Mode. You could also go to the homepage of you optical drive manufacturer & download a driver.
George Carlin
Reformatting My Picture Library
By fmagreed2 in forum ComputerReplies: 7Last Post: 3rd Feb 2011, 15:15 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 09:36 -
Reformatting Question
By jyeh74 in forum ComputerReplies: 2Last Post: 14th Jun 2010, 18:07 -
reformat computer - no sound
By jyeh74 in forum ComputerReplies: 18Last Post: 1st Jul 2009, 19:56 -
Reformat Hard Drive, HELP!!
By danl_9x in forum ComputerReplies: 27Last Post: 4th Jun 2008, 13:39
