OK, I have started the undaunting task of trying to transfer years of VHS tapes to DVD. I was able to get a couple of good captures when I first started, but now I can't get anything captured correctly.
System specs (pretty decent, in my opinion)
-P4, 2.8
-1 GB RAM
-80 GB system drive
-120 GB data drive
-250 GB SATA drive just for video stuff
-Sound Blaster Live
-XP Pro, SP2 [no viruses or spyware]
-ATI All-in-Wonder 9600 XT
-ADS DVD Xpress
Some of the problems: (I end-task on all unecessary programs and only use the capturing program)
[ATI]
-Can't install MMC 9.02. When I run the setup, the Install Shield just hangs... Through trial and error, I found that if I end-task on IDriver.exe, then Install Shield reports "1628: Failed to complete installation." [The DAO/MDAC and DVD Decoder portions installed correctly]
-w/ MMC 8.8 (what came on the CD in the box): The picture gets jumpy for about 2-5 seconds every 10-30 seconds.
[ADS]
-Using CapWiz 3.5: Anything captured from the VCR has severe audio problems - while captured, when replayed from the MPEG, and when replayed from a DVD created from the MPEG. It kind of sounds like a popping noise, almost like the audio is too loud. There is no setting to adjust the volume of the audio in.
-The top 2% of the screen is garbled.
UGGG. I feel like I spent waaay too much money on this already - I just want to get SOMETHING working! Any help would be appreciated!
I've got the same card, try using mmc 9.0.1. It was the only one I got to work.
Check out this thread:
http://rage3d.com/board/showthread.php?t=33738545
Particularly, step 2. After I did step 2 my system became much more stable. -
Install 8.7, it's the most stable one.
Thanks guys...
I have followed the steps in the rage3d.com message to completely rid my system of ATI and started over.
9.02/9.01 still would not install - following the steps given by ATI (MDAC/DAO first). I was able to install 8.7.
I can capture from TV and it looks and sounds great. When I try to capture from the S-Video input from a VCR, the picture is jumpy, and the sound is very much overblown. The same tape plays fine on a TV.
So, it's got to be either some settings in the MMC, or the purple dongle thingy. Any more ideas? -
*bump*
Any more ideas? I've got a stack of VHS tapes that are piled up in my office waiting to be transferred!
Regards the ADS DvdExpress
There is a ADS forum at http://p211.ezboard.com/fpyro1394frm8
The post I have read about "poping" noise talk about it occuring at edit points or stop/start on a vhs tape
The above forum are all ADS product users and may be able to provide more help with that device.
Capturing DV tape to one file, or multiple files by scene?
By Obtong in forum EditingReplies: 4Last Post: 12th Jul 2011, 13:03 -
Very specific question regarding capturing multiple sources
By Acester47 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 22:04 -
Capturing the same source multiple times
By richieclare in forum Capturing and VCRReplies: 0Last Post: 6th May 2010, 12:10 -
Problems joining multiple MPEG2 files together.
By MagicPockets in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2010, 10:47 -
Capturing multiple video sources
By mgy999a in forum Capturing and VCRReplies: 8Last Post: 14th Apr 2008, 04:20
