If I have a .mov file, how do I know if I should convert it to mpg or mpg2 in TMPGenc program? Which one will give me better results?
The file is 480x360.
VCD/MPEG1 = 352x240
SVCD/MPEG2 = 480x480
Thanks,
Rod
Hello,
Are you going to burn to vcd or svcd/dvd or leave it on the computer??? That should be your primary concern.
The vcd will be lesser quality. The svcd will be better than vcd. If your destination is svcd make sure the player you will use can play it (all pcs with mpeg2 codec can, not all dvd players can).
It looks like svcd is the closest conversion.
What is the bitrate of your source .MOV file? SVCDs support 2250 kbs max while VCDs support 1150 kbs max.
Encoding at a higher bit rate will not clear up any defects in your source. -
No, but using a as high bit rate as possible will make the encode as close to the original as possible, and not intruduce defects of its own.
/Mats -
Where do I find the bitrate? The source file is a .mov file. I view it in Quicktime. In quicktime I don't recall it showing the bitrate. I can look again, but I thought it just had stuff like 480x360 mpeg-4 ect.
What spec am I looking for to tell me if I should convert to mpeg 1 or mpeg 2 in TMPGenc?
Then for step 2 if I converted to mpg 1 or mpg2, would determine authoring it as vcd or svcd resectively. Correct?
Rod -
Originally Posted by Rod L
/Mats
How to convert a 1.83 GB .mov to 1000 MB .mov?
By moiz in forum Newbie / General discussionsReplies: 6Last Post: 31st Mar 2010, 15:31 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 04:59 -
Convert mpg2 to mpg for Movie Maker
By Cattis in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 13:01 -
convert .mov to .mpg
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 09:51
