Hey guys
Im having some problems with premiere. It gives me this message every time. " Premiere has caused an error in MSVCRT.DLL. Premiere will now close. If you continue to experience problems try restarting your computer." What do I do to fix this thing.
Closed Thread
Results 1 to 30 of 43
grrrr
i will have sony contact you directly and walk you through it .. as they are concerned you bought a product and failed to get to dealer support ..
just have your registration data handy as they will contact you soon .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
premiere 6.5 and vegas use different layouts ..
they are called tracks btw ...
premiere it is at the bottom and with 6.5 you dont have real time preview .. as you do w/ vegas , though with premiere pro , you do .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Ok, Im going to stick with Vegas 4.0, I actually got sound, what I did was I converted the video in tmpgenc to vcd, then I just ran them in vegas and they all worked.
My 2 problems with Adobe Premiere
By IT learner in forum EditingReplies: 2Last Post: 16th Sep 2011, 08:46 -
Premiere Cs3 Export problems
By owendude in forum EditingReplies: 3Last Post: 24th Jul 2009, 09:58 -
After Effects to Premiere... importing problems?
By Saibot in forum EditingReplies: 1Last Post: 21st Feb 2009, 22:48 -
Playback problems in Premiere
By JustinBaker in forum EditingReplies: 4Last Post: 7th Nov 2007, 10:41 -
Problems with slowmotion in Premiere Pro 2.0
By chrisal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Sep 2007, 14:07
