Hi.
My problem is very simple: I have some "Tom & Jerry" MPEGs encoded with stereo sound, but the channels are nearly identical to each other, so I want to make the audio stream in those MPEGs mono, in order to save disk space.
Is there a straightforward way to do this?
After contless trials-and-errors, my best approach has gone as follows:
1. Demultiplex the MPEG's video stream using TMPEGenc.
2. Extract the audio track from the original MPEG using VirtualDub.
3. Convert the audio track to mono using CoolEdit -> wave is now half the size.
4. Encode the audio track to MP2 using tooLAME.
5. Multiplex the video stream (m1v) and the mp2 audio using... WHAT?
The problem with step 5 is that all multiplexers I've tried (FlaskMPEG+bbMPEG, TMPEGEnc, Womble MPEG2VCR) fail to correctly multiplex the mono audio track: the resulting MPEG has a double-speed audio, which ends halfway the video, and the resulting MPEG's size is not close to the sum of the video+audio streams, but close to video size + 2 * audio size.
Am I missing something or it just isn't possible to multiplex mono streams into MPEGs?
Any answers appreciated.
Thanks.
Results 1 to 1 of 1
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 10:16 -
Basic question on MPEG-2 multiplexing
By nharikrishna in forum Authoring (DVD)Replies: 7Last Post: 2nd Feb 2011, 23:32 -
mono mpeg sound
By dvdfreak1971 in forum Video Streaming DownloadingReplies: 0Last Post: 20th Apr 2008, 14:41 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 17:01
