Results 1 to 9 of 9
  1. I have two separate vob files (burnt as data apparently) and I am unable to play them on my DVD player.
    Can someone tell me how to burn them as a single DVD please?
    Thanks in advance.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Thanks in advance.
    Open them in an editor that'll open .VOB, like Mpeg Video Wizard or Nero Vision Express. Edit, author, then burn
    Alternate plan: Demux the streams with Vobrator, open in any editor, edit, author, burn
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Make a video_ts folder. Put them in it. Put the video_ts folder as your main directory (ie d:/video_ts) Burn as a disc-at-once option in your software. Done.
    Kevin
    --remember to finalize if your software doesn't - that's why you should choose disc-at-once mode--
    tmpgenc dvd author. just put two vob files in a video_ts folder wont make a compliant dvd.
  5. Right, tried putting them in a folder VIDEO_TS - doesn't work,
    Also tried tmpgenc dvd author and this won't open the files as it state they are invalid.
    Please help.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Have you tried using the other programs that Capmaster suggested ? It may be that they are invalid or damaged from a DVD perspective, even if you can play them.
    As you discovered, following yoda313's advice got you nowhere. Just dumping the vobs into a video_ts directy isn't enough, as you do not have the ifo and bup files created during authoring, and without these, you do not have a DVD.
    Read my blog here.
  7. Tried all the above and failed miserably, anyone got any other ideas?
    Thanks,
    Vixal.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    what did tmpgenc dvd author say?
    you can try demultiplex the vobs using tmpgenc(separate video and audio) and import in tmpgenc dvd author. demultiplex guide
    May 2003
    you need to create the missing ifo/bup files .... use ifoedit and select create new ifo's then just selct the first vob file and let ifoedit do its work ... (save the new files in a folder named VIDEO_TS) create an empty folder named AUDIO_TS then burn both folders onto a dvdr and play
