Hi!
I have an AVI with ac3 sound but looking to GSpot I see that codec is AC3 (0x2000) bitrate 192 Kb/s monophobic CBR FS 48000 HzWhat does it mean? have I an AC3 mono or not?
Does exist an AC3 audio player for pc?
thanks in advance
haltman
Hello,
You could use a dvd player like powerdvd and check the configurations tab. It will tell you the number of channels the audio has. If its 5.1 audio it should say 6 channels as an example.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Change video, keep audio without re-encode ? Problems with strange AC3.....
By Gwar in forum EditingReplies: 18Last Post: 27th Aug 2011, 09:19 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
Strange AC3 mkv sync issues
By MarkyMarky in forum AudioReplies: 6Last Post: 6th Jan 2011, 09:40 -
Strange audio shift when using other audio track than default
By Heliooos in forum DVD RippingReplies: 2Last Post: 25th Mar 2010, 01:46 -
AC3 6ch audio strange behavior in AVISynth
By lovyagin in forum Video ConversionReplies: 10Last Post: 1st Mar 2010, 11:17
