I am using Womble for my edits on Vob files captured using a JVC DVD Recorder. I know if I use it to just clip out the parts I don't want, then generate a file for Authoring and Burning it won't re-encode my video so I don't lose quality.
I have some concert video from HDNet and I'd like to clip out some songs before authoring. To make things look a bit better I'd like to also have Womble fade in and out from black on each scene.
If I do this or use other transitions with Womble does it re-encode anything so I'm loosing quality on my video? If so is the loss ony on the transition? Any guides available for using transitions with Womble? I have viewed a couple for clip and paste and have no problems with basic stuff like that.
Thanks.
There is no way to make transistions without reencoding. However, I'm pretty sure (although not positive) that Womble will only encode the area around the transition. A simple experiment should be able to tell (you can pretty much tell by how long things take, if no other way).
womble will do a direct stream copy untill it gets to the transition..then it will reencode and then go right back to direct stream copy as soon as the transition is over.
basically any kind of transition you do will be subject to this, whereas simple cutting/rearranging will result in a direct stream copy.
dlv -
Additionally, when you are using Womble, from the Export menu, when you press the button to create the file, there is also a button that says "Details". Clicking this, you can see what portions are re-encoded, vs which is direct stream copy.
The process gets much slower (in the preview) during transitions and re-encoding. I like relatively quick transitions, and do not obsess about the quality being super-precise, so it works for me. -
The audio from my DVD recorder is AC3, If I only cut and splice Womble doesn't change this.
If I use transitions will womble still maintain the audio as AC3?
Thanks. -
the AC3 will just be directly copied over. you can verify by using the "details" option cited above.
I also wanted to specify that the direct stream copy will only occur if you keep the same resolution..etc. If you decide to change res/bitrate then eVERYTHING is getting re-encoded. So this is where it's important to capture at whatever resolution you want the final product to be.
dlv
what transitions to use and when ?
By codemaster in forum EditingReplies: 12Last Post: 22nd Mar 2011, 14:03 -
My transitions keep bugging out.
By Joeytwo in forum Newbie / General discussionsReplies: 0Last Post: 19th Feb 2011, 03:58 -
looking for transitions like in this video
By Twio X in forum Newbie / General discussionsReplies: 8Last Post: 9th Dec 2009, 04:02 -
How to Encode Womble Mpeg Video Wizard projects with HCenc
By tmw in forum User guidesReplies: 18Last Post: 10th Jul 2009, 14:49 -
how can i make transitions
By wan2no in forum Authoring (DVD)Replies: 3Last Post: 14th Jun 2008, 18:33
