I'm trying to capture AVI video (Huffyuv v2.2.1 - CCESP Patch v0.2 codec) using an ATI AIW 9600TX. I'v tested many codecs and have found that Huffyuv yeilds the best quality with smaller file sizes. The only problem i have is that in the resulting file that audio has about a 2 second delay. How do I resynch the audio? Are there any settings that i can change so the audio is not off in the first place (audio is captured a PCM)? Are there any better codecs to use when capturing AVI?
Thanks in advance
The distance between genius and insanity is measured only by success...
Originally Posted by trickyman
I'm currently using VirtualVCR with good results. Most captures are in sync. I've discovered my problem is my analog video captures. When you have 5 or six segments on one tape, the audio is off. I capture each segment seperatly, encode them seperatly then merge the MPG together with TMPGEnc tools. If I use VirtualDub and load all segments then frameserver to the encoder they will be out of sync.
Huffy give the best results but the largest of all files. PicVideo with 19 settings gives good video quality and much smaller files then HuffyUv.
I see you are using a ATI product so maybe LordSmurf might have soem good advice for you.
Take a look at http://www.digitalfaq.com/
LS
Audio Sync issue?
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 11:25 -
Avi to DVD and Audio Sync Issue
By macbuz in forum MacReplies: 21Last Post: 11th Jan 2009, 19:04 -
MKV to AVI, audio sync issue, not on PC, but on HDD media player
By danowat in forum Video ConversionReplies: 1Last Post: 12th Nov 2008, 04:53 -
Audio sync issue with
By 123fish123 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2007, 17:54 -
Audio out of Sync Issue.
By DSMKilla in forum Capturing and VCRReplies: 7Last Post: 17th May 2007, 00:27
