Hello,
Why not dvdshrink???? All you have to do is go to reauthor mode. Add the title you want. Go to the start end button and then select the scene you want. You'll get a fresh new vob with only the scene you want. And you can deselect audio/subtitle info if you wish. It should do exactly what you need.
or
mpegvcr
videoredo
tmpgenc dvd author
tmpgenc mpeg editor
tmpgenc
but they doesn't support any switchable subtitles, several audio tracks. -
thanks
but if there is better program
DVDshrink is very good
but whin i go to the start&end tool
it doesn`t give me the full freedom in
chosing any plcace to make start and end points
but it gives me specific points ( I don`t mean the chapters
but the slide bar )
Did you understand me
sorry for bothering you guys
Cut sides of Vob Files
By sash! in forum EditingReplies: 3Last Post: 12th Nov 2010, 14:57 -
cut scene out of .vob using SonyArchitect 5
By stevene in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 04:58 -
cut vob file
By xxxjojoxxx in forum EditingReplies: 8Last Post: 25th Dec 2008, 10:06 -
best, easiest way to cut bad section out of vob file
By dblake2 in forum EditingReplies: 2Last Post: 16th May 2008, 18:53 -
How to cut vob file by keeping DTS track
By sureshforum in forum EditingReplies: 2Last Post: 1st Feb 2008, 10:13
