MSU Lossless Video Codec published!
Giving the best compression ratio in the lossless video compression
field! (If any codec compress better - please send it to us!
This codec is intended for lossless video compression (used for saving master copies or intermediate rendering results).
The project is in beta-version stage. Good results in compression are already achieved, now working on codec's speed.
Free installer avalable from:
http://www.compression.ru/video/ls-codec/index_en.html
Enjoy!![]()
Results 1 to 9 of 9
With regards
Dmitriy Vatolin
http://www.compression.ru/video/ (News: new metrics and WMP vs JPEG-2000 comparison)
Senior editor of Compression-links.info -
If it's truly lossless, that'll rock the video world 8)
Installer it's free! It also has a lossy modes but all comparison (and charts) was in fully lossless mode.
With regards
Dmitriy Vatolin
Originally Posted by DmitriyV
It has built in Temporal denoising and Spatial denosing!
What that means? It means that (in theory) you can capture and at the same time filter what you capture.
My first tests show me results like the dynamic noise reduction ( value at 6 ) and 2D cleaner optimised ( Values 8 - 1 - 1)
Not bad at all!
The Medium compression reminds me Huffyuv ...
The High compression reminds me PicVideo after slighty filtering!
I wish to see the speed version of your codec. It's going to be 5 to 10 times faster. Now it drops frames like hell in my system (when use for capture)La Linea by Osvaldo Cavandoli
On a P4 2.4 with 1GB RAM it dropped almost 300 frames in 10 seconds using either VVCR or iuVCR. None of my other codecs drop frames.
Maybe it gets its "best compression ratio" by not capturing 99% of the frames
Seriously, this needs to at least not drop frames in order to be useful. -
I don't believe that they have in mind capturing the way we do...
Maybe the next version could do capture,but I don't believe CPUs less than 2Ghz will ever able to handle it!La Linea by Osvaldo Cavandoli
Originally Posted by trockHello.
Do I take any old avi file and test this codec with it? I tried in VirtualDub and it said it would take 49 days to render a 7 minute video. 1 frame every 2 seconds...
Lossless codec did THIS to a video i made...help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2011, 06:49 -
Which codec/container makes lossless video editing possible?
By ilimitus in forum EditingReplies: 14Last Post: 29th Jan 2011, 13:06 -
MSU MPEG-4 AVC/H.264 2011 Video Codec Comparison - CALL FOR CODECS
By DmitriyK in forum Latest Video NewsReplies: 1Last Post: 28th Jan 2011, 15:27 -
lossless video-codec good for editing in Premiere
By phpmysql348 in forum Video ConversionReplies: 4Last Post: 11th Jun 2008, 21:41 -
Can't convert screen capture video (MSU SCLS codec)
By nonsey in forum Video ConversionReplies: 13Last Post: 27th Apr 2008, 04:20
