  1. I download some software from a newsgroup and the filename has the extension 'BIN'
    What am I supposed to do ? Not used to work with files having this extension in the filename. Is it an image file ?
    Thanks !
  2. Yes.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Mount the image using Daemon Tools to see what files the image contains
