i'm trying to rip this dvd-9 movie i have using dvdshrink. however, dvdshrink won't make it small enough to fit 1 disc. so now, is there some other dvd tool i can use to make it smaller? if not, what program can i use to take out the 'Extras' completely? dvdshrink won't let me do it... heres a pic just incase;
Results 1 to 15 of 15
Sure it will. Hit the Re-author button. Then drag the main movie title from the right side to the left side. Voila! Main movie only. Now you can uncheck any audio or subtitle streams you don't want. Presto change-o!
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Originally Posted by Shocker Milwaukee
i need to keep the menu the way it is.. -
Originally Posted by Cobra281
I've used VOBBlanker to good effect...
Hope that helps.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
You can always re-shrink the files that resulted from the initial shrink. Use the available quality enhancement option to improve the image if necessary.
"The avalanche has already started; it is too late for the pebbles to vote." -
When you reauthor, you should just select the main movie to shrink. You will loose the menu functions. In full disk mode, you should slect automatic, the size will then be set to fit a siingle dvd.
What I do is I select "Custom Ratio" for menus, extras etc. and set them as low as they will go. I leave the main movie on "Automatic". DVD Shrink will then fill up the DVD-R no bother. I also use the Deep Analysis function, and if the main movie compression is below 70% I set AEC (Adaptive Error Correction) to Maximum Smoothness. Otherwise, I leave it on Sharp (Default).
As Frunobulax has already said, if the output is still too large (which shouldn't happen) you can always simply re-shrink it.
Cobra -
Have you checked out the guides for DVD Shrink?
You can eliminate extras by deselecting them just as you would to eliminate audio soundtracks in other languages
Oops. Just tried to deselect extras. Can't do it. -
Originally Posted by Cobra281"The avalanche has already started; it is too late for the pebbles to vote."
Cobra281
If I understood correctly you want to keep your menus but are not interested in extras.
If so, go to the extras and click on the "+" sign to open the different extras.
Now you can select for each extra the type of compression you want:
- highlight the title
- In the top-right window (where ususally is automatic and in your first image is "mixed compression") select "Still images". It woul replace the extra with a default image that says "Feature Removed".
- This usually reduces the title to 10 to 20% of the compressed size.
- Repeat for other titles in the Extras
Looking at your original DVD it would be enough to get within the size limit .
PabloNewbie to DVD backup -
Just select automatic for everything. Chances are the quality will be fine even if it indicates that compression will be 60%. If you select custom ratio for most things, you will end up with a files that is too big. If you don't want the extras, but do want the menu, you can either use vob blanker, or select still photo for that extra. But you should leave the main movie on automatic.
Originally Posted by jyn999"The avalanche has already started; it is too late for the pebbles to vote."
I never use the still photo option, as it takes up too much space, and I never saw the point of killing an extra to replace it with photos anyway.
I have a couple of things I use instead
1. A black bitmap. This gives you the smallest replacement of the lot.
2. Custom still using a photo or poster taken from the movie, reminding me that the extras have been removed or shifted to a second disk.
3. Studio logo still fulfilling the same roles as item 2.
Any of these will eat a lot less space that still photos.Read my blog here.
Witch the best way to convert a BluRay Movie to MKV ( size DVD9 or else)
By siopilos in forum Blu-ray RippingReplies: 9Last Post: 12th Feb 2012, 20:59 -
movie length into a avchd dvd9
By supersam in forum Authoring (Blu-ray)Replies: 11Last Post: 14th Oct 2009, 00:42 -
I want to backup DVD9 movie to single 4.5G blank disc
By byungsoo in forum DVD RippingReplies: 1Last Post: 6th Oct 2009, 00:09 -
MS Movie Maker and buring DVD
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2009, 16:49 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 18:41
