Hi , I am using dvd shrink to make a compilation of songs from different concerts
i am using the re author function, and selecting the start and the end of each song.
when i am playing the final dvd on a stand alone dvd machine, the music of each song is different from the one before "there is no normalize function in shrink"
and there is no fade in fade out for each song
N:B each song will be played on a new tittle
can i put these songs in one tittle and different chapters?
I use TMPGEnc DVD Author to do stuff like that. Demux the audio and video for each song in DVDDecrypter and keep using the "Add File" for each song into the same track.
OR you can use Womble MPEG-VCR if you take the songs from DVDShrink. Put each song in a seperate folder....then open each song in Womble and save it an an MPEG back to the same folder.
However as I recall....TMPGEnc DVD Author sometimes messes up doing it this way...I always try to have the files demuxed for TMPGEnc DVD Author.
Here's an example of one of my DVD's:
Mine dont fade in and out BUT I believe Womble has that option. These individual songs were all taken from a full length DVD that I made. -
WHat di d you think DVD SHrink was for? It's onlly to back up a DVD you own. Not to do all sorts of post editing such as audio fade in and fade out or normalizing. You have a movie you treasure, so you do not want to take a chance on scratching it during normal playing and what not. SOOOO you make a BACK UP. That is what it is for and it does that and even more just dandy.
There are plenty of other specialized tools that will do all you wish to do. Shrink is a backup or copy tool.No DVD can withstand the power of DVDShrink along with AnyDVD! -
Originally Posted by jtoolman2000
Lets see....he will need a program that will enable him to actually SEE and HEAR the song he wants to take....Hmm....DVDShrink.
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 12:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 05:04 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 13:33 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 20:58
