I have a LifeVeiw TV Tuner card. When I try to capture in VirtualDub, It has started giving me a message saying:
Video device already in use
You cannot use this device when another video application, such as DVD, video confrencing, video editing, TV veiwers, or WebTV for Windows is already using it.... yadayada.
I click oik, then it brings up Video Source box. I click the Lifeveiw TV Tuner and click OK.
I get: Error 418: Capture device was not detected
Then I get: VirtualDub cannot connect to the desired capture driver. Trying all avalible drivers
Then I get: PANIC: VirtualDub cannot connect to any drivers!
I have had it going a few times. Nohting is using the TV card that I can see. Tried restarting and loading VirtualDub straight away, but the same happens. I reinstalled the TV card drivers. Didnt change. I have win 2000.
I also have win 98 on another hdd and it works fine under this.
If this is a common problem and heaps of new guys like me ask this, just a link to a thread will do me. I know what its like with Newbies coming from maxima.org
I had this problem with that PANIC error.Do the following.
Go to (let me open VDUB,1 sec)...........crap stupid son of a ........its giving me a huge message ive never gotten before (the one you typed).Well do this.Go to the video or capture thing at the top and check where you see your card name and stuff and under that there should be like WDM (or something else)Microsoft Image Capture (or something like that) and choose that.It should then work.Now i have to go and fix this crap!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I can't quite follow what you mean. I have VDub 1.4.7
Problem with Virtualdub
By pranjev in forum Newbie / General discussionsReplies: 25Last Post: 30th Dec 2011, 12:16 -
A virtualdub problem
By General Mortars in forum ComputerReplies: 4Last Post: 10th Oct 2010, 06:01 -
VirtualDub Problem
By jarko in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 12:26 -
VirtualDub problem
By nic3 in forum Video ConversionReplies: 3Last Post: 1st Dec 2009, 13:29 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
