Hi,
I am trying to encode a movie through TMPGenc Xpress 3.0 but keep getting the error message - No quoted number of character-string '%.2f' when i click to output.
Why is this and how do I sort it? cheers
bizt
Check to be sure you have over 5 GB's on your Temporary drive. If not, change it to another partition that does and see if that helps.
Tom -
Hi again,
The destination disk is an external iomega hard drive and it has about 38gig free. I did read that somewhere about space but it doesnt seem to be that.
Ive also read that older c: drives formated as FAT32 can handle anything above 4gig files but mine is NTSF. Some one mentioned something about setting the cache in preferences but I dont know much about that.
Is there anything else that may cause it?
Bizt -
My next move would be to go to www.tmpgenc.net and go to the forums and look around. That's about the best i can offer.
Tom
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 03:17 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
Burn a DVD - Number of Frames error
By p_uriel in forum Video ConversionReplies: 5Last Post: 21st May 2008, 18:07 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56
