I have a m2v movie file & a PCM audio file that I want to convert to a mpg file. I purchased TMPGenc to do this but unfortunately it appears that its not possible. When I go to multiplex the audio stream, TMPGenc comes up with a "Multiplexing Linear PCM Stream to system stream is not supported"
Any suggestions on how I can overcome this problem.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
If you plan on authoring this video as a DVD and your authoring program supports elementary streams, just leave them the way they are and let the authoring tool mux everything together.
Use FFmpegui to create an .AC3 file from your .WAV..
Although the .AC3 file isn't 100% within spec, i haven't found a DVD player that wouldn't playback yet...
Very simple to use also.
When you're done, then authour... -
just fire up TMPGenc using the wizard thing, tell it to open up you wave as the audio source, leave video balnk, set it to CBR MP2 .... click next a couple of times, have a look for any other settings you might want on the way, then hit go
unless of courde yor using TMPGenc 3 express or whatever its called ..... then i dunno
adnkiich .... if iauthour anything using PCM audio then my shitty although resonably expensive DVD player refuses to play the audio .... maybe just a reason for falco trying to do this
RMVB - AVS - M2V/MPG Audio Unsyncs
By koberulz in forum Video ConversionReplies: 7Last Post: 13th Aug 2011, 16:38 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Noob Troubles: DVD w/ Multi-Angles & Commentary + m2v & ac3 joining
By ssfblue in forum Newbie / General discussionsReplies: 5Last Post: 28th Nov 2007, 11:54
