Hey all...
I am SO CLOSE to creating my IDEAL VCD template, I have fixed some sound issues, color, bitrate, etc. I have one thing left to do though! I cant get it right!
Resolution. I dont want to make it standard VCD (NTSC-352x240, PAL-352x28, but the SAME RESOLUTION AS THE SOURCE. I know that this will work as long as I ENCODE THE BLACK BARS! Please, someone tell me the exact settings I need to do this in TMpeg....As in the source, and output settings.
Many thanks will be given. I have gone through too many coasters already.
Set the aspect ratio option to "full screen (preserve aspect ratio)", and then set the target resolution to match the resolution of the Divx (you may have to unlock the settings to accomplish the latter).
According to VCD specs the output resolution must be 352x240/288. Let's say, you have a 320x176 Divx, select video arrange method "center[custom size] 320x176" and output res 352x240/288. TMPG add the borders.
Truman, what if the source resolution (divx) is wider than output, like DVD resolution... is the same procedure? answer also to fbporto@icqmail.com if possible, ok?
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Resolution problems when converting with FUW
By Malicious in forum DVD RippingReplies: 1Last Post: 8th Aug 2008, 01:02 -
resolution divx
By surfer in forum DVD RippingReplies: 22Last Post: 6th Jul 2008, 08:28 -
Converting resolution size
By Illusionist in forum Newbie / General discussionsReplies: 17Last Post: 11th Mar 2008, 01:38 -
DIVX convertor / resolution
By surfer in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 03:56
