I seem to have a huge number of audio codecs installed on my system. In some cases, there is more than one which handle the same format tag, and I worry that perhaps they are conflicting.
Can someone suggest a good way to manage audio codecs? And which ones do I really need?
Hi LisaB,
Your installed codecs can be managed from the Device Manager - accessed from the "System Properties" in your Windows Control Panel.
As for which ones do you really need - well, only you can decide that. AVICodec will be able to tell you which codecs are used by different media files.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Best compression program/format/codecs without losing quality
By adrian2055 in forum Video ConversionReplies: 12Last Post: 20th Jan 2011, 15:29 -
Is zero config a good way to manage a wireless network?
By SingSing in forum ComputerReplies: 13Last Post: 29th May 2010, 14:50 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 00:25 -
How to manage audio in Vista
By Lovepeaceguru in forum AudioReplies: 4Last Post: 12th Mar 2008, 14:08 -
Good free program to join .mpa audio and .mpg video ?
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 5th Nov 2007, 09:34
