SORRY BUT IM PROBALY IN THE WRONG FORM BUT DOES ANYONE NO OF THE QUICKEST WAY TO SHARE VIDEO FILES,IM IN AUSTRALIA AND MY FAMILY LIVE IN IRELAND AND I WANT TO SEND THEM VIDEO FOOTAGE OF US ERE,CAN ANYONE SUGGEST A QUICK WAY TO DO THIS .
THANKS
Results 1 to 9 of 9
one problem solved can solve alot of problems
What format is the video footage on, (dvd, vhs, avi..etc)
And please dont use capital letters for typing, its considered as shouting. -
First, turn off your Caps Lock. Don't shout
If you have access to a web host, like Yahoo or another hosting service, you can upload your files there. Then you can e-mail the web link of the files to them.
Another way could be to have them join a P2P service like WinMX, Kazaa Lite, etc. Then put a very uniquely-named file in your public directory, with no description, and e-mail them the file name. Then they can search for the filename using the service and download it that way -
sorry bout the caps,im sending the footage as wmv the smallest i can convert it and keep a bit of quality.
one problem solved can solve alot of problems -
use this service (its free)
http://s1.yousendit.com/
or
http://www.yousendit.com/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
or
does anyone no how fast the tranfer rate is with this,by the way both sides have cableone problem solved can solve alot of problems -
they have multiple t3 connections on a oc48 backbone (its fast enough) , but depends on how many people are up/downloading a day ..
"Transferring over 2,831,157,964,800 bytes per day'
thats a lot of bandwidth .. ive used them lots of times .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by magheraWant my help? Ask here! (not via PM!)
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
