I put the lame_enc.dll in both the Windows and Windows/System32 directory...but how do I "register" it? I don't understand why the ACM version of Lame comes with an INF installer file, but the the lame_enc does not...
Did you right click on LameACM.inf and select Install from the context menu?
Yes, I did...LameACM is installed...but that has nothing to do with lame_enc.dll....if you look at the inf file in notepad, it only deals with the ACM files, not the lame_enc.dll.
Are there not registry entries associated with lame_enc.dll? Is lame_enc.dll not an audio codec? Could someone please explain this? The Lame website is useless and contains no instructions. -
AFAIK lame_enc.dll is an encoder, not a codec.
But you can register dll files with this command: regsvr32 [filename.dll]
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 13Last Post: 22nd Jul 2016, 22:39 -
Which audio codec I need to enable for playing "cook/ffcook" audi
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 19th Sep 2009, 00:10 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 15:29 -
Help/info on IV50 "Indeo Video 5" codec....
By petruccibanez in forum MacReplies: 3Last Post: 4th Apr 2008, 01:22 -
Can't work with or find codec for "OpenDivx 4" files
By Lolipop Jones in forum Video ConversionReplies: 5Last Post: 14th Jun 2007, 16:43
